Tire/rim combo ?
cj71z
I've seen pics of the 92's and they appear to be flat where the lugs are. These seem to have a small square where the lugs are. Check out the bottom left rim in the pic. Any info on tires? At +12 could I run 225/ 50 r15 or should I stick with 215/50 r15 to clear the strut.
Thanks
Well....
A quick thumbnail calculation is that on a 240Z you have about 5 inches before you interfer with the strut. So the basic equation is:
Offset (Max) = 127-(Tire width/2)
For you question that works out to an answer of 14.5mm. But, there are other factors that influence the result. It would be good to hear from someone who had actually mounted the tires on the car before spending the money for the tires.
Your worst case for interferrence (with the strut at least) is on the front of the car.
So by that formula the calculations for a 215/50 r15 leaves me with 7.5mm which is a little more than 1/4 of an inch... Does anyone have 215/50 r15 and if you do how far does the tire "bubble" out... Thanks for the help
I was just doing some tire shopping of my own and I found that the 215's will be best for that size width. I have 7.5's and I have 215s on it that say they will fit 7-8" rims. at 7.5, the tire is about straight up and down with the width of the rim. So any larger then 215s for a 7" would be pretty bulbousy for the rim and I wouldnt want to risk it hitting the struts when you can just go for the 215s for safety. Just my 2c Good luck!
hmmm 225 rubber with +12 offset might rub...i have a set of 15x7 zero offset enkei's right now and was pretty close. if interested i might sell my set of enkeis, has a very nice lip, deep dish...popular on many old cars.
mike
What type Enkeis are they? I may be interested. :stupid:
  • Who's Online   1 Member, 0 Anonymous, 524 Guests (See full list)
