January 9, 200520 yr comment_108033 About re-creating a tail light panel as a single piece instead of the three. Are you sure the original panel is not comprised of three pieces for a reason? Link to comment https://www.classiczcars.com/forums/topic/14359-carbon-parts-post-suggestions/?&page=10#findComment-108033 Share on other sites More sharing options...
January 9, 200520 yr comment_108036 so roughly.. how much do you think some of those parts will cost? Are they reasonably priced.... or ALOT of money??! Link to comment https://www.classiczcars.com/forums/topic/14359-carbon-parts-post-suggestions/?&page=10#findComment-108036 Share on other sites More sharing options...
January 9, 200520 yr Author comment_108043 Alfadog said: About re-creating a tail light panel as a single piece instead of the three. Are you sure the original panel is not comprised of three pieces for a reason?If you're sitting on info about the 3-piece design - please share it. I have no idea about why the panel consists of 3 pieces. I might not havebeen clear enough about that it will be checked properly so it will be compatiblewith surrounding/existing parts in mind.Neither money nor orders will be accepted until the parts have been made and tested for my car. Might as well point this out. PrOxLaMuS© said: so roughly.. how much do you think some of those parts will cost? Are they reasonably priced.... or ALOT of money??!Don't know any prices yet. Check the one I posted on the cowl plate earlierin the thread. That's the only estimate I've gotten from SCE so far. Link to comment https://www.classiczcars.com/forums/topic/14359-carbon-parts-post-suggestions/?&page=10#findComment-108043 Share on other sites More sharing options...
January 9, 200520 yr comment_108056 just so people don't look back... US$370-400 for the cowl plate..thanks Mull Link to comment https://www.classiczcars.com/forums/topic/14359-carbon-parts-post-suggestions/?&page=10#findComment-108056 Share on other sites More sharing options...
January 10, 200520 yr comment_108062 Alfadog said: Are you sure the original panel is not comprised of three pieces for a reason?Possibly related to repairability. i.e. not having to replace the whole thing if only one corner of the car gets damaged. Link to comment https://www.classiczcars.com/forums/topic/14359-carbon-parts-post-suggestions/?&page=10#findComment-108062 Share on other sites More sharing options...
January 10, 200520 yr Author comment_108067 Bambikiller240 said: Possibly related to repairability. i.e. not having to replace the whole thing if only one corner of the car gets damaged.That's the first thing that came to my mind as well. Not enough reason to change from 1-piece to 3-piece though, I'd say.If a corner would get damaged, you probably have more damage to your car to get more upset about. It's not exacly a vulnerable spot - like the front spoiler for instance. Link to comment https://www.classiczcars.com/forums/topic/14359-carbon-parts-post-suggestions/?&page=10#findComment-108067 Share on other sites More sharing options...
January 10, 200520 yr comment_108068 Probably not. Link to comment https://www.classiczcars.com/forums/topic/14359-carbon-parts-post-suggestions/?&page=10#findComment-108068 Share on other sites More sharing options...
January 10, 200520 yr comment_108095 Yea, not sure why it is a 3 piece design. A 1-piece should be OK. Perhaps your supplier could make an attempt at both design prototypes to find out. Link to comment https://www.classiczcars.com/forums/topic/14359-carbon-parts-post-suggestions/?&page=10#findComment-108095 Share on other sites More sharing options...
January 10, 200520 yr comment_108098 The tail section is in three pieces (IMHO) because the build quality of the original cars was poor. I have seen many cars where the panel fit is slightly different on the rear panel so the width is slightly different (have seen up to 1.5CM)- three pieces allows you to compansate for how big the back panel ACTUALLY is.The guy who is making mine found out to his cost that it is harder to fit a one piece than a three piece because of discrepancies in the steel panel fitment. Link to comment https://www.classiczcars.com/forums/topic/14359-carbon-parts-post-suggestions/?&page=10#findComment-108098 Share on other sites More sharing options...
