Email logins are now active ×
L24 piston markings
240znz
This relates to my original question about the overhaul. I would guess that the engine has been overhauled in which case this is most likely a +50 piston set. Factory piston sets were: standard, ovesize 1 tru oversize 5. Measure the piston diameter, STD spec is 82.99 mm to 83.04 with the oversize 5 being 84.47 to 84.52. The importance of this is that if you plan to overhaul the engine it may be at max wear limit which would require you to install cylinder liners in the block. :ermm: JLP
  • Who's Online   1 Member, 0 Anonymous, 395 Guests (See full list)
