De-varnish the valve cover?
TomoHawk
Well if it is all over the inside of your valve cover, wouldn't it make sense that a similar layer was all over lots of other places in your engine that you DON'T see without a complete teardown?
As seen in this thread, that stuff is plastered on pretty good. I think the odds of it just flaking off of its own volition are pretty small.
The only thing that I remember being on the underside of the valve cover that you would want to remove is that hard putty sealant that they put on the splash guard for the vent hole. That stuff IS hard, and after 30 years is bound to be cracked and ready to disintegrate into little shards of hard gunk. Probably not hard enough to damage a valve or a lifter, but I'll bet they cold play havoc on a small oil passage down below.
Enrique
aircraft stripper is a really powerful chemical available at your local auto store, or Wal-Mart, which basically strips anything and everything off of metal...
used for removing paint from cars and stuff.
But be very careful! it ate through 2 layers of rubber gloves, and disintigrated a plastic brush I had...
very strong stuff... but does miracles!
I used Dupli-Color Textured Metallic coating.. also available at nearly all auto stores
