Posted January 9, 200520 yr comment_108019 hey guys, just got me a Z (83 280zx) its rough, but i love it and its rebuildable. anywho, i went to my local scrap yard and raped a z for all i could get at one time. i noticed that the previous owner of my Z removed the fuel injector cooler. the Z i found had it so i took it and all the hardware...just wondering how crucial is that part? -carlo Link to comment https://www.classiczcars.com/forums/topic/14604-im-new-herequick-question/ Share on other sites More sharing options...
January 9, 200520 yr comment_108048 Welcome-this site is really aimed at the 70-78 Zs(S30 series), but the injector/rail cooler is crucial in hot weather (90F plus) if you are parked for less than 20 minutes-stops vapor lock caused by heat soak(made far worse by high ambient temperatures) not really important otherwise.Will Link to comment https://www.classiczcars.com/forums/topic/14604-im-new-herequick-question/#findComment-108048 Share on other sites More sharing options...
January 15, 200520 yr comment_108713 Some say it is, others say it isnt, in my experience if your are in continuous hot area, then you would need it, a way to alleviate this is to dump the stock rail.I did for a nice aluminum rail and have yet to have a problem with my turbo 240. Link to comment https://www.classiczcars.com/forums/topic/14604-im-new-herequick-question/#findComment-108713 Share on other sites More sharing options...
January 15, 200520 yr comment_108734 I live in SoCal where the summer temps reach the 90s-low 100s. I own two EFI Datsuns w/o the injector cooler and have never experienced the heat soak/vapor lock problem. Link to comment https://www.classiczcars.com/forums/topic/14604-im-new-herequick-question/#findComment-108734 Share on other sites More sharing options...
January 15, 200520 yr comment_108757 Tell you what if by chance you exp.vapor lock.install it.I've put units on 70-78to keep them a little cooler.or you can fix it up and put it on just because itlooks cool.. JZM Link to comment https://www.classiczcars.com/forums/topic/14604-im-new-herequick-question/#findComment-108757 Share on other sites More sharing options...
