15" Rewinds
Go240Zags
i just got some silver 15" rewinds mounted on my '71 240z and they look sweeeet. I also got some new tires to go with them (Radial T/A - 225/60/15). im having an issue however fitting the Konig center caps on the front wheels :(
I have falken ziex 512s on my neon right now, in 205/60/14. The foot print is not as wide as an equivalent would be of yokohama es100s, for example. They aren't very sticky, but do last for a bit. I've been running them since august.
if you can spend extra dough, I'd get es100s instead. I have those on my Z in 225/50/15
Could you post some pictures?
I seem to recall reading somewhere that the front caps can be put on if you install the center caps before mounting the wheel.
  • Who's Online   1 Member, 0 Anonymous, 566 Guests (See full list)
