Hello ya all, I am having a problem with my 280z, it idles rough and I checked the vacuum advance unit and it isnt holding air, it looks to be the original unit. Does anyone know where to get one online. Is there anything else I should check, I wish I could send a link to let you guys know what it sounds like but I dont know how to do that, I's an idiot to the web :stupid:, but is there anything else I should check, I havent changed the fuel filter for about 2 years could this be a problem too. Any ideas would be a great help
https://www.classiczcars.com/forums/topic/14676-vacuum-advance/
If the Vac advance "isn't holding air" it's probable that the diaphram has a leak. The BB most likely came from the "cage" Tomohawk referred to. These are 2 separate parts. Maybe you can find a used distributor, cheaper than buying the parts?
