Posted January 19, 200520 yr comment_109207 Has anyone ever heard of steel headlight covers for a 240 Z? I would like to weld them in place and paint them body color. Link to comment https://www.classiczcars.com/forums/topic/14700-steel-headlight-covers/ Share on other sites More sharing options...
January 19, 200520 yr comment_109212 Be aware that if your 240Z is an early model it may well have plastic headlight buckets. Link to comment https://www.classiczcars.com/forums/topic/14700-steel-headlight-covers/#findComment-109212 Share on other sites More sharing options...
January 19, 200520 yr Author comment_109220 Thanks for the info Mike. I'll check the car tomorrow to see if the buckets are plastic. Have you ever heard of someone painting the clear covers with paint? Would painted covers stand up to weather etc... I just really like the look of some of the race cars that I've seen with this modification.Thanks again, Brett Link to comment https://www.classiczcars.com/forums/topic/14700-steel-headlight-covers/#findComment-109220 Share on other sites More sharing options...
January 19, 200520 yr comment_109236 If you are referring to the fiberglass fill in to the headlight scoops that are used for racing, be aware that they eliminate the function of the headlight itself. So would painting a set of clear headlight covers.If your plans are to convert your vehicle into a day only driver, then go ahead, but if not, the mod you're thinking of will not work.Enrique Link to comment https://www.classiczcars.com/forums/topic/14700-steel-headlight-covers/#findComment-109236 Share on other sites More sharing options...
January 19, 200520 yr comment_109238 the early 240Z headlight buckets were fiberglass.... the later ones and 280Z's had metal Link to comment https://www.classiczcars.com/forums/topic/14700-steel-headlight-covers/#findComment-109238 Share on other sites More sharing options...
January 19, 200520 yr comment_109249 I have made molds to produce fiberglass covers that are blended in and painted. Headlights have to be moved to the grill area. I'll take a pic of mine tonight if you want to see it. Link to comment https://www.classiczcars.com/forums/topic/14700-steel-headlight-covers/#findComment-109249 Share on other sites More sharing options...
January 19, 200520 yr comment_109278 You can paint the plastic ones and remove them at night time. Link to comment https://www.classiczcars.com/forums/topic/14700-steel-headlight-covers/#findComment-109278 Share on other sites More sharing options...
January 19, 200520 yr comment_109349 In most cases I don't believe it is legal to have lights that you have to get out of the car to operate, so removing painted plastic ones when you need light in most states is probably not an option. Here are a couple of pics of mine, the freshly blended one is mine, the other one (passengers side) is an original Bob Sharp racing item from the 70's. Link to comment https://www.classiczcars.com/forums/topic/14700-steel-headlight-covers/#findComment-109349 Share on other sites More sharing options...
January 20, 200520 yr Author comment_109385 Lance,You have done exactly what I want to do. I was also going to move the headlights to the grill area. Would you consider selling a pair of your fiberglass headlight covers?Thanks, Brett Link to comment https://www.classiczcars.com/forums/topic/14700-steel-headlight-covers/#findComment-109385 Share on other sites More sharing options...
January 20, 200520 yr comment_109432 Hi Brett,I was hoping to sell a couple sets to help recoup my cost for making the molds, I haddn't gotten far enought to think about a price but I will and I'll PM you about it.I moved the stock lites into the grill but have never been happy with the arrangement, and I'm planning to go to the pick and pull once the weather gets better and look at something from like a Camaro that will be mounted tighter to the bottom of the hood behind the grill. Once I get that figured out I'll put some pics in my gallery showing how it works. Link to comment https://www.classiczcars.com/forums/topic/14700-steel-headlight-covers/#findComment-109432 Share on other sites More sharing options...
January 20, 200520 yr comment_109466 Just came across these on eBay. Link to comment https://www.classiczcars.com/forums/topic/14700-steel-headlight-covers/#findComment-109466 Share on other sites More sharing options...
January 20, 200520 yr comment_109489 Those are the originals, BSR was the only ones that I know of that made them back in the 70's Link to comment https://www.classiczcars.com/forums/topic/14700-steel-headlight-covers/#findComment-109489 Share on other sites More sharing options...
