Tire Size?
CoastGuardZ
Tomohawk, Ponchovisa
You can calculate the overall tire diameter in inches using the following formula:
(section width X aspect ratio X 2)/25.4 + wheel diameter(in inches)= diameter
For example: 195/70R14 would be:
(195 X .7(or 70%)X 2(both sides of tire))/25.4(mm per inch) + 14 = 24.748"
You can use this formula to compare any wheel/tire combination you are considering. (Width, offset and backspacing also need to be considered.)
Hope this helps,
Doc.
I found this while looking for vintage tires for a mate
http://www.longstonetyres.co.uk/productPage.php?productID=713&categoryFilename=radial.php
This states that a 175TR14 (not quite a 175R14 but might be the same aspect ratio) is 634 in dia and 172 wide. So using "Doc's 280" formula and working backwards you get (working in mm so changed formula a little)
(section width X aspect ratio X 2) + wheel diameter(in inches)x25.4 = diameter
((diameter - wheel diametre (in inches)x25.4)/2)/section width = aspect ratio
((634-14x25.4)/2/175 = 0.795
so the 175TR14 is equal to a 175/80/14 which from what I have read in other forums is correct. I believe the reason Nissan change from the 175R14 to the 195/70/14 as both have the same rolling dia of approx 630 or 24.8 inches
Hope this helps
bfgoodrich radial ta,cooper cobra,yokahama avis s/t,michelin pilot xgt h4,falken ze-502 ziex 502,these are all the tires I could find in 225/60/14 I bought the bfgoodrich because they are the widest of the bunch at 7.2" waiting for them now the falkens are the cheapest in price and cooper is an american owned company made right here in the united states
  • Who's Online   1 Member, 0 Anonymous, 498 Guests (See full list)
