Posted January 25, 200520 yr comment_110110 Hi guys ... mm i got a question here and i have no idea whats with my 260Z.. as i reach 110km/h the left rear wheel vibrates ... what do i hav to check or change? Link to comment https://www.classiczcars.com/forums/topic/14763-rear-wheel-vibrates-at-110kmh/ Share on other sites More sharing options...
January 25, 200520 yr comment_110112 Start with getting the wheel balanced. Link to comment https://www.classiczcars.com/forums/topic/14763-rear-wheel-vibrates-at-110kmh/#findComment-110112 Share on other sites More sharing options...
January 25, 200520 yr comment_110122 Or just rotate the wheel to another position and see if the problem stays with the wheel or with the suspension. Link to comment https://www.classiczcars.com/forums/topic/14763-rear-wheel-vibrates-at-110kmh/#findComment-110122 Share on other sites More sharing options...
January 25, 200520 yr comment_110125 Do you ALWAYS get the vibration, or just sometimes? I feel a vibration occasionally on the highway with my newer car, but I assume it's from wavy pavement. Sometimes. Occasionally a little 'hop' after the car sits for a few days. Link to comment https://www.classiczcars.com/forums/topic/14763-rear-wheel-vibrates-at-110kmh/#findComment-110125 Share on other sites More sharing options...
January 25, 200520 yr comment_110126 If the tire/wheel is not out of balance, it could be that the strut on that corner of the car has gone bad and is allowing the wheel and tire to bounce at high speeds. You could have someone follow you down the road and observe that corner ofthe car to see if this is happening. If it is bouncing, replace the struts. Link to comment https://www.classiczcars.com/forums/topic/14763-rear-wheel-vibrates-at-110kmh/#findComment-110126 Share on other sites More sharing options...
January 25, 200520 yr comment_110128 All good points so far, tire balance can definitely cause the vibration you mention as can rough pavement. However, I have one more thing to add and that is the U-joint that connects the half-shaft to the wheel.I had a bad u-joint on my left rear wheel which caused a massive vibration in the tire which led to the lug nuts flying off and the wheel passing my car at 60+mph. Not something you want to have happen. When I took it to the mechanic to fix the damage, he mentioned that the U-joint more than likely caused the problem. So, for what it's worth, have that checked as well.Enrique Link to comment https://www.classiczcars.com/forums/topic/14763-rear-wheel-vibrates-at-110kmh/#findComment-110128 Share on other sites More sharing options...
January 25, 200520 yr comment_110156 I tend to agree to EScanlon - don't discount other factors such as U-joints.I have the same sort of vibration, coming from the left rear wheel. I was told to investigate:1. wheel balancing2. suspension3. de-laminated tire (or broken steel belt)I've had the vibration with two different suspension set-ups, so it's definitely not that.I rotated the wheels to make sure it wasn't balancing or tire problems. but still it vibrates!I now think it's either the U-joint, or perhaps an off-balance drive shaft? Vibrations have a funny way of starting in one place but ending up in another - sometimes a wobble in the rear isn't actually caused by rear-end componentry?Good lucK! Let me know if you have any success, because I'll be trying the same thing! :stupid: Link to comment https://www.classiczcars.com/forums/topic/14763-rear-wheel-vibrates-at-110kmh/#findComment-110156 Share on other sites More sharing options...
January 25, 200520 yr comment_110157 U-Joints could cause it too, so check that soon. If U-joints are bad, they will self-destruct in a relatively short time ( 2K miles tops)If a driveshaft was out of balance, the noise wouldn't be isolated to one side of the car. (were you referring to an Halfshaft?) Link to comment https://www.classiczcars.com/forums/topic/14763-rear-wheel-vibrates-at-110kmh/#findComment-110157 Share on other sites More sharing options...
January 27, 200520 yr Author comment_110313 Mmm i just came back from the workshop & the mechanic said that there is a damage on the U-joint, but then there are no parts available in my country to replace or fix it .... do you guys know where i could order these parts? Link to comment https://www.classiczcars.com/forums/topic/14763-rear-wheel-vibrates-at-110kmh/#findComment-110313 Share on other sites More sharing options...
January 27, 200520 yr comment_110315 You could order them from suppliers in the USA:http://www.courtesy-nissan.com/http://www.zcarparts.com/ther are other places also, but these are the ones that use. Link to comment https://www.classiczcars.com/forums/topic/14763-rear-wheel-vibrates-at-110kmh/#findComment-110315 Share on other sites More sharing options...
January 27, 200520 yr comment_110344 the mechanic said that there there are no parts available in my country to replace or fix it ....Keep that in mind whever you think you need a repair. Except for common things like brake pads & shocks, oil/air filters, etc., you'll need to get the parts in advance, or put off a repair (leave car in shop) until parts arrive, or repair things yourself. Even brake pads & shocks, filters, etc. can be hard to find, so you'll want to stock up on consumables in advance. Link to comment https://www.classiczcars.com/forums/topic/14763-rear-wheel-vibrates-at-110kmh/#findComment-110344 Share on other sites More sharing options...
February 5, 200520 yr Author comment_111420 Hey guys, it wasnt the u joint after all which caused the problem, it's because of the wheels which were lack or armour alls hehe just joking well i just found out that mayb it was the differential mount which made the knocking sounds, i havent tried replacing it though, im still waiting for the new ones hope it works :rambo: Link to comment https://www.classiczcars.com/forums/topic/14763-rear-wheel-vibrates-at-110kmh/#findComment-111420 Share on other sites More sharing options...
