Posted February 3, 200520 yr comment_111209 hey fans! just wondering if anyone can help me decode my vin number....im not really sure what year my car is.....edit: ive tried various recorces...but they say my VIN number is not long enough...i hvae 11 didgets NOT 17.... any suggestions? Link to comment https://www.classiczcars.com/forums/topic/14858-vin-decoding/ Share on other sites More sharing options...
February 3, 200520 yr comment_111218 Post your VIN here and we'll be able to tell you about your car. Keep in mind that these older and smaller numbers don't contain any encoded information (color, options, etc.) that newer VINs do. However, the first few letters, HS30, HLS30, etc. will help us identify the specific model and the actual serial number part will help narrow down the manufacture date and/or model year. Link to comment https://www.classiczcars.com/forums/topic/14858-vin-decoding/#findComment-111218 Share on other sites More sharing options...
February 3, 200520 yr comment_111219 So what's the VIN # you have?? Should start out something like HLS30-xxxxxx. Depending on what the "Chassis" number is will tell you approx. date it was made. The VB LTD. catalog has a pretty good listing in the front that helps decode chassis numbers...webdawg1 Link to comment https://www.classiczcars.com/forums/topic/14858-vin-decoding/#findComment-111219 Share on other sites More sharing options...
February 3, 200520 yr Author comment_111220 hls30218079late 74? Link to comment https://www.classiczcars.com/forums/topic/14858-vin-decoding/#findComment-111220 Share on other sites More sharing options...
February 3, 200520 yr comment_111221 H=L24 or L28 depending on year, yours is L28L=Left hand driveS30=model # of our Z cars218079=218,079th S30 produced (roughly) Link to comment https://www.classiczcars.com/forums/topic/14858-vin-decoding/#findComment-111221 Share on other sites More sharing options...
February 3, 200520 yr Author comment_111222 ok---than was my car supposed to come with a 5 speed, or was this added after purchase..or coudl it be added as an option in 74? Link to comment https://www.classiczcars.com/forums/topic/14858-vin-decoding/#findComment-111222 Share on other sites More sharing options...
February 3, 200520 yr comment_111223 218079=218,079th S30 produced (roughly)Correct me if I'm wrong, but I think this means it's the 218,079th left-hand-drive S30 produced (roughly)? Link to comment https://www.classiczcars.com/forums/topic/14858-vin-decoding/#findComment-111223 Share on other sites More sharing options...
February 3, 200520 yr comment_111224 Furthermore,G=2+2 (blank for coupes)H=L24 or L28E (depends on model year) this would be an R for L26'sL=Left hand driveS30= car modelA=AutomaticF=5spd (blank for 4spd)U=Federal Emissions or UV=California Emissions or UN=Canada EmissionsThis help any? Newer VIN's are the longer numbers that you refer to... the VIN you have is correct for your car. Link to comment https://www.classiczcars.com/forums/topic/14858-vin-decoding/#findComment-111224 Share on other sites More sharing options...
February 3, 200520 yr comment_111225 Sounds about right. It would still be considered a "1975" tho. Production date 12/74-7/75 would be for chassis numbers 200001-270000, so that would fit in toward the front end on that run. Hope this helps...webdawg1 Link to comment https://www.classiczcars.com/forums/topic/14858-vin-decoding/#findComment-111225 Share on other sites More sharing options...
February 3, 200520 yr Author comment_111226 ok, so therefore my car is a 75 car bought in 1974, 4 speed (modified to hold a 5 speed)? Link to comment https://www.classiczcars.com/forums/topic/14858-vin-decoding/#findComment-111226 Share on other sites More sharing options...
February 3, 200520 yr comment_111227 Correct me if I'm wrong, but I think this means it's the 218,079th left-hand-drive S30 produced (roughly)?I would say you are correct Alfa... I'm not an expert by any means. Link to comment https://www.classiczcars.com/forums/topic/14858-vin-decoding/#findComment-111227 Share on other sites More sharing options...
February 3, 200520 yr comment_111228 ok, so therefore my car is a 75 car bought in 1974, 4 speed (modified to hold a 5 speed)?I'd say you've got it nailed down now. Link to comment https://www.classiczcars.com/forums/topic/14858-vin-decoding/#findComment-111228 Share on other sites More sharing options...
