Posted February 4, 200520 yr comment_111302 Hey guys.. I recently bought a T3 Garrett turbocharger from a later Z31 turbo... and after looking at the turbo.. I need some help figuring out which parts are the inlets? and which are the outlets?? I THINK it is water-cooled... but I am not sure.. can you guys help me out? Is the OIL INLET correct? Is the OIL OUTLET correct? Is that center piece the water cooled inlet? or is it not watercooled? Link to comment https://www.classiczcars.com/forums/topic/14865-turbo-guys-need-your-help-picture/ Share on other sites More sharing options...
February 4, 200520 yr comment_111311 Ajax,What you have is water cooled, and the round port is where the water goes.On the oil passages, the one with the larger opening is the drain-the oil comes out frothy. The specs of the turbo-other than being water cooled-are the same for the 280ZXT and the early model 300ZXT.Will Link to comment https://www.classiczcars.com/forums/topic/14865-turbo-guys-need-your-help-picture/#findComment-111311 Share on other sites More sharing options...
February 4, 200520 yr Author comment_111340 awsome Thanks!! Link to comment https://www.classiczcars.com/forums/topic/14865-turbo-guys-need-your-help-picture/#findComment-111340 Share on other sites More sharing options...
