After looking at some photos in struck me that the GTO conversion for the Datsun and the Daytona Couple have almost exactly the same lines almost all the way around. Any one ever think of buying the kit and using it as a starting point to make your z into a Daytona couple knockoff?
https://www.classiczcars.com/forums/topic/14885-daytona-couple-conversion/
The fender line is similar, but not the same, he headlight openings are similar, but not very close, the Hood line is completely different.
With the amount of work needed to make them really close, you would probably be better off to get the front clip you really want.
Will
