Posted February 8, 200520 yr comment_111867 I have a 76 280z and this is part of the throttle body. I just aquired an 1980 zx engine but the BCDD is missing. It is located on the bottom of the intake manifold and not the throttle body (see diagram). I was just curious what this does and if there another name it goes by? http://www.classiczcars.com/photopost/showphoto.php?photo=14001 Link to comment https://www.classiczcars.com/forums/topic/14920-what-the-hell-is-a-bcdd/ Share on other sites More sharing options...
February 8, 200520 yr comment_111871 Boost Controlled Decelleration Device. When you get your foot out of the gas, it stabilizes the idle-necessary because of the abrupt change in vacuum-if I understand it correctly.Will Link to comment https://www.classiczcars.com/forums/topic/14920-what-the-hell-is-a-bcdd/#findComment-111871 Share on other sites More sharing options...
February 8, 200520 yr comment_111885 Will is correct! It was a smog prevention device. Typically when you get out of the gas you will get a richer condition until the rpm subsides....the smog police didn't like this situation as you can imagine. Link to comment https://www.classiczcars.com/forums/topic/14920-what-the-hell-is-a-bcdd/#findComment-111885 Share on other sites More sharing options...
February 8, 200520 yr Author comment_111919 Thanks guys. I just called Nissan and they want $323 for a new one! eeeeeebay !!!! Link to comment https://www.classiczcars.com/forums/topic/14920-what-the-hell-is-a-bcdd/#findComment-111919 Share on other sites More sharing options...
February 8, 200520 yr comment_111936 I have a complete '76 engine I will sell you for less!If you have a non egr intake, we could trade complete intakes...Will Link to comment https://www.classiczcars.com/forums/topic/14920-what-the-hell-is-a-bcdd/#findComment-111936 Share on other sites More sharing options...
February 9, 200520 yr Author comment_111984 Actually I just bought a mint condition 1980 280zx engine that has been in storage for 25 years. Only had 1900 miles on it. So the BCDD that I need is for an 80 and it's located on the intake not on the throttle body. See diagram above also see the engine at: http://www.classiczcars.com/photopost/showphoto.php?photo=14002Follow the pvc hose to the left end of it, go straight up and you will see a flat spot on the intake manif. that's where it mounts. Link to comment https://www.classiczcars.com/forums/topic/14920-what-the-hell-is-a-bcdd/#findComment-111984 Share on other sites More sharing options...
