Posted February 12, 200520 yr comment_112416 Hi All,currently converting a 4dr 240K GL (1976) from auto to manual using a 240Z 5 spd gearbox.My question ... is a 240K coupe auto driveshaft the same length as a 4dr 5 spd manual driveshaft? Been hunting around for a 4dr manual one that will be what I need but cant locate one, the only one that I know of is a 2dr auto driveshaft so I would like to know it that would fit...Thanks in advance,Cuong Link to comment https://www.classiczcars.com/forums/topic/14967-240k-auto-to-manual-conversion/ Share on other sites More sharing options...
February 12, 200520 yr comment_112439 Cuong your 4dr 240K auto shaft will fit behind the 5 speed box without modification ( I'm assuming you've got one to begin with!) Link to comment https://www.classiczcars.com/forums/topic/14967-240k-auto-to-manual-conversion/#findComment-112439 Share on other sites More sharing options...
February 12, 200520 yr comment_112484 Hi Coung, I didn't know you had a 240K! Can you post pictures for us please! As for your question, I don't know but I do know the hardtop and sedan have the same wheelbase! HKS has already answered the question anyway so it's alright. Anyway, HKSZ, how come you know so much about 240K's? Hmm?? Link to comment https://www.classiczcars.com/forums/topic/14967-240k-auto-to-manual-conversion/#findComment-112484 Share on other sites More sharing options...
February 13, 200520 yr comment_112520 1600's, Zed cars, 240K's its all good :classic: Link to comment https://www.classiczcars.com/forums/topic/14967-240k-auto-to-manual-conversion/#findComment-112520 Share on other sites More sharing options...
February 13, 200520 yr Author comment_112538 thanks for the prompt reply guys. the problem is that the previous owner kept the 240k 5 spd and its tailshaft to fit into his 1600 (not sure why he kept the tailshaft as the 240K is a two piece one and I am pretty sure the 1600 are a one piece shaft) and gave me the 4 spd from the 1600 and no tailshaft!it used to be a auto 4 dr 240k but has been converted to manual. I am now putting one of my 240Z 5 spd gearboxes behind the L24. i might just have to take some measurements and see if the 2dr are the same part, will let you all know what i find out.thanks,Cuong Link to comment https://www.classiczcars.com/forums/topic/14967-240k-auto-to-manual-conversion/#findComment-112538 Share on other sites More sharing options...
February 15, 200520 yr comment_112792 Cuong,Coupe & sedan tailshafts for 240K's are the same length, whether it's 4/5 speed or auto doesn't make a difference; all tailshafts for this model are the same length and are straight swaps.James Link to comment https://www.classiczcars.com/forums/topic/14967-240k-auto-to-manual-conversion/#findComment-112792 Share on other sites More sharing options...
February 15, 200520 yr Author comment_112843 hi James, thanks for the information. i ended up buying a stuffed 240k 2 dr auto tailshaft as well as a 1978 C210 skyline one. the k one was damaged in the front section (the rubber bit) so i had to mix and match the two (the C210 rear half is sligthly longer than the K one) now its all in the car, so the problem is solved Cuong PS is the rubber part in the middle section replaceable or not? Link to comment https://www.classiczcars.com/forums/topic/14967-240k-auto-to-manual-conversion/#findComment-112843 Share on other sites More sharing options...
February 15, 200520 yr comment_112894 Good question!I've never encountered that problem, but I'd think the whole mount/rubber unit would need replacing.It's a tricky looking thing that, I'll check the factory manual tonight and see what I can find.James Link to comment https://www.classiczcars.com/forums/topic/14967-240k-auto-to-manual-conversion/#findComment-112894 Share on other sites More sharing options...
February 27, 200520 yr comment_114305 Hmmm. You have a 240K with a 240Z gearbox, and I have a 240Z with a 240K gearbox. (I also have a 260Z gearbox which i'll probably put in the 240Z once i know if the ratios are ok). Link to comment https://www.classiczcars.com/forums/topic/14967-240k-auto-to-manual-conversion/#findComment-114305 Share on other sites More sharing options...
