Hi All,
currently converting a 4dr 240K GL (1976) from auto to manual using a 240Z 5 spd gearbox.
My question ... is a 240K coupe auto driveshaft the same length as a 4dr 5 spd manual driveshaft?
Been hunting around for a 4dr manual one that will be what I need but cant locate one, the only one that I know of is a 2dr auto driveshaft so I would like to know it that would fit...
Thanks in advance,
Cuong
Hi Coung,
I didn't know you had a 240K! Can you post pictures for us please!
As for your question, I don't know but I do know the hardtop and sedan have the same wheelbase! HKS has already answered the question anyway so it's alright. Anyway, HKSZ, how come you know so much about 240K's? Hmm?? :P
thanks for the prompt reply guys.
the problem is that the previous owner kept the 240k 5 spd and its tailshaft to fit into his 1600 (not sure why he kept the tailshaft as the 240K is a two piece one and I am pretty sure the 1600 are a one piece shaft) and gave me the 4 spd from the 1600 and no tailshaft!
it used to be a auto 4 dr 240k but has been converted to manual. I am now putting one of my 240Z 5 spd gearboxes behind the L24.
i might just have to take some measurements and see if the 2dr are the same part, will let you all know what i find out.
thanks,
Cuong
Cuong,
Coupe & sedan tailshafts for 240K's are the same length, whether it's 4/5 speed or auto doesn't make a difference; all tailshafts for this model are the same length and are straight swaps.
James
hi James,
thanks for the information. i ended up buying a stuffed 240k 2 dr auto tailshaft as well as a 1978 C210 skyline one.
the k one was damaged in the front section (the rubber bit) so i had to mix and match the two (the C210 rear half is sligthly longer than the K one)
now its all in the car, so the problem is solved :)
Cuong
PS is the rubber part in the middle section replaceable or not?
Good question!
I've never encountered that problem, but I'd think the whole mount/rubber unit would need replacing.
It's a tricky looking thing that, I'll check the factory manual tonight and see what I can find.
James
Hmmm. You have a 240K with a 240Z gearbox, and I have a 240Z with a 240K gearbox. (I also have a 260Z gearbox which i'll probably put in the 240Z once i know if the ratios are ok).
