Clutch?
cremmenga
Ok so my Z is coming along well now! after a week of 15hr at college and 35 hours at work, the weekend finally came! I have almost all paint off my car and I finally found car in my bondo ( the root of all EVIL). To make along story short my clutch doesn't work, when you press in on it, with no resistence it goes right to the floor. I tried bleeding it, but i think it just leaks air to much. I bought a new master and slave cylider, I hope that is what i needed. Please inlighten me with your clutch knowledge and tell me if this is the right thing to do or if it is something else. THANKS AGAIN
Well i tried bleeding the lines but there was no end to the air coming out, and the top lid to the master cylinder turned out to not be sealing at all, who knows what else was not sealing. So you think with this new master and slave it will fix it? I hope so I want to drive it next weekend if i can find out how to tune the valves and ect!!
The lids to the master cylinders have vents and are not supposed to seal completely. I just sounds like the old master was shot and needed to be replaced. Personally I will rebuild the wheel cylinders when they are good enough , but I never rebuild a Master. As Bambisnuffer said take a close look at any and all of the rubber brake lines , and replace them if there is a question if they are surviceable. bean
