Email logins are now active ×
ARP rod bolt torque?
ZSaint
Hi ZSaint,
I to am in process of rebuilding a lack luster SCCA ITS engine with 8mm rod bolts...So I gave ARP a call..info from ARP website.
I called Pete at ARP and he told me that 30 pounds with the moly lube is the recommended torque value.
Good Luck with the build up
Hope you got a good deal on those rods!!! :classic:
david
From an ARP build sheet:
Rod Bolt part # 202-6003
Use ARP Moly Assembly Lubricant to lubricate the threads of the bolt and nut face.
ARP recommends using the STRETCH METHOD for torquing blots. Follow instructions for using a stretch guage. Stretch bolts to .063 - .067.
If you do not have a stretch guage, follow these steps using the ARP Moly Assembly Lube. After the rods are installed into the motor, torque bolts to 40 ft lbs. Loosen the nuts. Torque to 40 ft lbs again. Loosen the nuts and torque to 40 ft lbs a third and final time.
ARP (805) 339-2200
