March 10, 200520 yr comment_115963 about time someone other than my dad and i did this!except we used Re-bar positioned in a triangle, so that way it only took one bath for the parts. left them there 12 hours a piece. everything came out great! Link to comment https://www.classiczcars.com/forums/topic/15038-electrolytic-rust-removal/?&page=3#findComment-115963 Share on other sites More sharing options...
March 11, 200520 yr Author comment_116292 Here is what my L24 block looked like before I attempted electrolytic rust removal on it. It had been degreased, but the rust remained. The guys at the machine shop said "it's not as bad as it looks" when I picked it up. It sure looks bad to me. After 24 hours in the solution, this is what the garbage can looked like. When you know that the rust-colored stuff is rust rising off of your parts, this is a beautiful sight. And after about 40 hours in the can, this is what she looks like after some light brushing and rinsing. I immediately blew some air on and in her, used my paint dryer to dry out the cylinders and internal surfaces, and dabbed some WD40 on. I think I'll get some primer and paint her this weekend. Not bad, huh? Link to comment https://www.classiczcars.com/forums/topic/15038-electrolytic-rust-removal/?&page=3#findComment-116292 Share on other sites More sharing options...
March 11, 200520 yr comment_116298 Not bad. Beautiful Link to comment https://www.classiczcars.com/forums/topic/15038-electrolytic-rust-removal/?&page=3#findComment-116298 Share on other sites More sharing options...
March 11, 200520 yr comment_116316 Some days, there just isn't much better than a hot bath!Will Link to comment https://www.classiczcars.com/forums/topic/15038-electrolytic-rust-removal/?&page=3#findComment-116316 Share on other sites More sharing options...
March 11, 200520 yr comment_116321 ........especially with a little current running through it. just ask anyone on death row. Link to comment https://www.classiczcars.com/forums/topic/15038-electrolytic-rust-removal/?&page=3#findComment-116321 Share on other sites More sharing options...
March 12, 200520 yr comment_116329 OOOH, that tingles!-things an L series block might say while in an electrolytic bath!Will Link to comment https://www.classiczcars.com/forums/topic/15038-electrolytic-rust-removal/?&page=3#findComment-116329 Share on other sites More sharing options...
March 13, 200520 yr comment_116524 Why don't you wire yourself up and see what it's like? Link to comment https://www.classiczcars.com/forums/topic/15038-electrolytic-rust-removal/?&page=3#findComment-116524 Share on other sites More sharing options...
March 13, 200520 yr comment_116525 Do you think you could adapt this process to work with nuts & bolts? Something like a rock tumbler drum made of steel...thx Link to comment https://www.classiczcars.com/forums/topic/15038-electrolytic-rust-removal/?&page=3#findComment-116525 Share on other sites More sharing options...
March 13, 200520 yr comment_116531 Why don't you wire yourself up and see what it's like?We have you as an example of what it's like. Link to comment https://www.classiczcars.com/forums/topic/15038-electrolytic-rust-removal/?&page=3#findComment-116531 Share on other sites More sharing options...
March 13, 200520 yr comment_116537 Right. You have me as an example of a perfect, highly-educated, intelligent person. Link to comment https://www.classiczcars.com/forums/topic/15038-electrolytic-rust-removal/?&page=3#findComment-116537 Share on other sites More sharing options...
March 13, 200520 yr comment_116539 Right. You have me as an example of a perfect, highly-educated, intelligent person.(ten characters) Link to comment https://www.classiczcars.com/forums/topic/15038-electrolytic-rust-removal/?&page=3#findComment-116539 Share on other sites More sharing options...
June 4, 200519 yr comment_126370 This is Her Majesty the 26th, bare naked metal and 100% rust free. She also has some holes where rust used to be. Poor thing. She is just out of the tank and has not been wiped down yet. These pictures are from this morning. She sat in the electrolysis tank for three days after all the paint and junk was stripped off. The plastic covering on the wire harness metal tabs has not been harmed nor has any of the lead filler. She is 100% rust free inside and out. Cool, huh? Link to comment https://www.classiczcars.com/forums/topic/15038-electrolytic-rust-removal/?&page=3#findComment-126370 Share on other sites More sharing options...
