Posted February 20, 200520 yr comment_113486 I spent a few hours hunched over my computer looking for a speedo cable last night and found a great big fat zero. I am guessing I have the origianl 240 4 speed manual. Any suggestions would be greatly appreciated. And btw this site is the best I have found so far on the Z. Link to comment https://www.classiczcars.com/forums/topic/15050-73-240z-speedo-cable/ Share on other sites More sharing options...
February 20, 200520 yr comment_113488 Hi JT:See http://www.classiczcars.com/forums/showthread.php?t=13638&page=1&pp=15&highlight=Mack+Speedo+cable Post #1 and #20 Our member ChrisA provided that info. Link to comment https://www.classiczcars.com/forums/topic/15050-73-240z-speedo-cable/#findComment-113488 Share on other sites More sharing options...
February 20, 200520 yr comment_113502 Vb sells them, $25 or so. MSA probably also caries them.Will Link to comment https://www.classiczcars.com/forums/topic/15050-73-240z-speedo-cable/#findComment-113502 Share on other sites More sharing options...
February 20, 200520 yr Author comment_113527 Thanks for the quick replies. I just bought my 240 in January so VB and MSA are??? Link to comment https://www.classiczcars.com/forums/topic/15050-73-240z-speedo-cable/#findComment-113527 Share on other sites More sharing options...
February 20, 200520 yr comment_113529 Victoria British http://www.victoriabritish.com/ and Motor Sport Auto www.zcarparts.com Probably the two most plentiful parts resources. Link to comment https://www.classiczcars.com/forums/topic/15050-73-240z-speedo-cable/#findComment-113529 Share on other sites More sharing options...
February 20, 200520 yr comment_113541 MSA lists P/N #45-4101 for $79 (catalog printed 3 years ago)V/B lists P/N69-100 for $19.95 (newest ctatalog 2005 Winter)Bet there is a difference in quality as well. Link to comment https://www.classiczcars.com/forums/topic/15050-73-240z-speedo-cable/#findComment-113541 Share on other sites More sharing options...
February 20, 200520 yr comment_113545 I have the one from VB-different from the OEM piece-I'll post a picture of the oem and the VB pieces here a little later tonight(The boy is home, and a hunting/layout trip to the Zroom will require Mom to watch him when she gets home from work.)Will Link to comment https://www.classiczcars.com/forums/topic/15050-73-240z-speedo-cable/#findComment-113545 Share on other sites More sharing options...
February 21, 200520 yr comment_113578 Here are the pictures of the speedometer cables, obvious quality differences between them, the OEM unit has a spring wound about 18" to keep the cable out of trouble, both ends are metal, and there was a rubber seal to keep dirt out of the cable. It is too dark for good pictures, I will take more in the morning if that will help. If the offering from MSA is OEM, that's what I will do when this one goes away. Will Link to comment https://www.classiczcars.com/forums/topic/15050-73-240z-speedo-cable/#findComment-113578 Share on other sites More sharing options...
February 22, 200520 yr Author comment_113733 Thanks for the info. I'll let you know when I get it in... or when I don't and ask for help Link to comment https://www.classiczcars.com/forums/topic/15050-73-240z-speedo-cable/#findComment-113733 Share on other sites More sharing options...
