Posted February 22, 200520 yr comment_113760 Has anyone tried using one of these kits and if so was it worth it? I saw a segment of Classic Car restoration where they used one of these kits and a regular home oven and it looked great. Harbor Frieght has a basic unit for $70, and saw some on ebay for about the same. Just thought it would a nice alternative to painting engine bay parts that would fit into the oven. Jeff Link to comment https://www.classiczcars.com/forums/topic/15073-home-powder-coating-kits/ Share on other sites More sharing options...
February 22, 200520 yr comment_113773 I think those kits you saw on the Classic car sows is from the Eastwood company. ( www.eastwoodco.com )Just don't use your kitchen stove. Get a spare in a shed or garage. Link to comment https://www.classiczcars.com/forums/topic/15073-home-powder-coating-kits/#findComment-113773 Share on other sites More sharing options...
February 22, 200520 yr comment_113816 On another site I vist there was a simular thread, the HF guns were given the thumbs up. Small parts were baked in a toster oven, larger in a full size. And like Tom said don't use the house oven, could give you a once in a lifetime bad tasting roast from the nasty chemicals that may stay behind.I'm considering building a larger box from sheetmetal and making it easy to assemble/disassemble and insulate it with fiberglass bats and just install my own heating elements and control. These are pretty cheap from stove repair places and the setup would allow for larger/more pieces at a fairly low investment since I'm not planning on making a living doing this stuff... Link to comment https://www.classiczcars.com/forums/topic/15073-home-powder-coating-kits/#findComment-113816 Share on other sites More sharing options...
February 22, 200520 yr comment_113829 If you just wanted a heated box, why not just strip down an electric oven, or better yet, take the coils from the top and mount them inside, or on the sides. Do you think you could uncoil those heating elements from the stovetop and make your own pattern for rthe inside? Link to comment https://www.classiczcars.com/forums/topic/15073-home-powder-coating-kits/#findComment-113829 Share on other sites More sharing options...
February 23, 200520 yr comment_113834 would it not be a lot easier to go to the local panel shop and ask can you usetheir hot oven painting booth or hire it for a short period of time Link to comment https://www.classiczcars.com/forums/topic/15073-home-powder-coating-kits/#findComment-113834 Share on other sites More sharing options...
February 23, 200520 yr comment_113837 Might also be cheaper and a hell of a lot less hassle to take what you need to the powder coaters. Chances are they'll do a better job than you can with your "home kit". Hell, if you are doing a heap of zeds then maybe it would be worth the capital expenditure on building/buying an oven, the kits etc, but surely not for a one off resto project! Link to comment https://www.classiczcars.com/forums/topic/15073-home-powder-coating-kits/#findComment-113837 Share on other sites More sharing options...
February 23, 200520 yr comment_113889 my brother got his 57 chev coupe done at the powder coatersit was a good joband it must not have been that expensive to have it donehe is not a tight arse but he does believe in good pricesrob Link to comment https://www.classiczcars.com/forums/topic/15073-home-powder-coating-kits/#findComment-113889 Share on other sites More sharing options...
February 23, 200520 yr comment_113891 First you have to have a powder coaters to take it too, if you don't then doing it at home becomes an only option. Link to comment https://www.classiczcars.com/forums/topic/15073-home-powder-coating-kits/#findComment-113891 Share on other sites More sharing options...
February 23, 200520 yr comment_113935 I think it's OK to do small parts at home. anithing bigger than, say a brake caliper, should go to a commercial outfit. Link to comment https://www.classiczcars.com/forums/topic/15073-home-powder-coating-kits/#findComment-113935 Share on other sites More sharing options...
