Email logins are now active ×
Fan shroud
Alex 240Z
Hi John
I'm bringing a bunch of parts to the swap meet for Z Fest in Orlando tomorrow. I have a fan shroud. It's off my husbands 77. You can have it if you want it. It is made of plastic and it's 2 pieces. If it doesn't fit your car you can just pitch it.
Vicky
Thanks but I will not be making Z-Fest this year just been to busy and a little late to register and get things together. I will definitly be there next year and will be looking to meet all you people from the west coast you seem like a terriffic bunch !!!! Seems like a lot more older make Z fans there lot of newer z cars here 350's 300's and 280ZX fans here !!!!! It is good to see all the old school Z owner are around !!!! Can you hold the fan shroud until next year :knockedou ?
There are no types sold that I know of and there may be more. They are Water-Wetter which is sold at Autozone, so PeP-Boys must sell it also and then there is Radiator Relief that is sold by DEI. DEI can found at most speed shops along with water wetter.
The 2-piece fiberglass fan shroud from a '77 Z will not fit your 240Z if equipped with the original radiator. The MSA shroud one-piece shroud does fit but it is marginal at the top where the radiator guard is located. I got mine securely mounted after some mods to the fiberglass in this area.
I have a 280Z fan shroud on my 1972 240Z. All it took was a bit of trimming on the shroud, and I made 2 brackets out of 18 gauge sheet metal to mount it. It makes a big difference in water temps when stopped in traffic on hot days.
  • Who's Online   0 Members, 0 Anonymous, 791 Guests (See full list)
