$5 - $10,000
Need a lot more details and pictures of the "standard" problem areas for anyone to give you an educated guess. After that, the area of the country it is in will make a difference as well.
here are some more details on the car.Car has been sitting since 2002.original orange paint,a little faded.Body is straight.No rust under hatch,floors look to be clean too.Interior is in good condition,rip on the drivers seat.Original engine/tranny.Only thing changed here are the carbs(to round ones).Here is the link to pictures.
http://public.fotki.com/glebka/72_240z/
the fact the car hasn't ran since 2002 will have make you assume a certain amount of repair or maintance will have to be done to make it roadworthy , gas tank, carbs and brake work to start with, so that has to be figured into its worth if comparing it to other running z prices, a car that runs is huge plus :)
seerex is right, plus
pictures aren't good enough to judge the intergrity of the chassis.
Frame Rails, inner fender under the battery, rocker panels, etc.
FWIW, If it's a 72, it came from the factory with round top carbs
