Posted March 2, 200520 yr comment_114812 hey guys,for the reason listed in my "strong gas scent" thread and the fact that i think my car would run better with it i was thinking of stepping down from whatever big race cam i have that makes my car lope, though that part is cool, to something smaller and much milder. has anyone used motorsport cams and if so how do you like them? any other brands anyone would recommend? i know crane is the big name and they also have a sizable price attached to them. maybe i should just step back to stock cam for a bit.thanks for your time everyone,brian -broken74- Link to comment https://www.classiczcars.com/forums/topic/15165-motorsport-cams/ Share on other sites More sharing options...
March 2, 200520 yr comment_114813 For a L6 engine, changing out cams is not just a matter of changing the bump stick. If you call MSA, they will enlighten you. Link to comment https://www.classiczcars.com/forums/topic/15165-motorsport-cams/#findComment-114813 Share on other sites More sharing options...
March 2, 200520 yr Author comment_114814 oh thats' right i have to change lash pads and springs and all that other crap. damn. nonetheless any advice aside from it being a big pain in my arse to do it would be appreciated. Link to comment https://www.classiczcars.com/forums/topic/15165-motorsport-cams/#findComment-114814 Share on other sites More sharing options...
March 2, 200520 yr comment_114815 Another option may be to alter the valve timing by moving the cam sprocket.You may need to "play" around with this as I can't remember if I retarded or advance my cam to reduce the "lumpiness"I sure someone else will chime in with the correct solution.MOM Link to comment https://www.classiczcars.com/forums/topic/15165-motorsport-cams/#findComment-114815 Share on other sites More sharing options...
