kcdc Posted March 6, 2005 Share #1 Posted March 6, 2005 Hey, need some advice for a novice again. I've learned know the firing order for a L28 is 153624 (counterclockwise) on the distributor, my questions is that when I trace the wires to the actual plugs on the head the order doesn't make sense to me (not in order as they come off the distributor, or in numerical order).Please let me know the order (from front of the car to the firewall) that the sparkplug wires should be in at the plug itself. Is it 153624 as well?, if so, I've found my problem...Thanks in advance...KCDCKeith1976 280z Link to comment Share on other sites More sharing options...
Bambikiller240 Posted March 6, 2005 Share #2 Posted March 6, 2005 Hey, need some advice for a novice again. I've learned know the firing order for a L28 is 153624 (counterclockwise) on the distributor, my questions is that when I trace the wires to the actual plugs on the head the order doesn't make sense to me (not in order as they come off the distributor, or in numerical order).Please let me know the order (from front of the car to the firewall) that the sparkplug wires should be in at the plug itself. Is it 153624 as well?, if so, I've found my problem...Thanks in advance...There is only ONE firing order. 153624 Period.The cylinders are numbered 1 thru 6. ONE is at the front of the engine, SIX is at the rear. The Distributor fires the plug wires in sequential order (counterclockwise)See attached picture of a 240Z distributor cap (for this purpose it's the same as one for a 280Z) The numbers shown indicate which CYLINDER (Spark Plug) that wire should be connected to. Link to comment Share on other sites More sharing options...
kcdc Posted March 6, 2005 Author Share #3 Posted March 6, 2005 The cylinders are numbered 1 thru 6. One is at the front of the engine, 6 is at the rear. BEAUTIFUL, that's what I needed was the Cylinder numbers...THANKS...I had saved your Distributor picture with the numbers previously, that's a great referrence for the "novice group". I also liked waht I found in searching threads 15 - too youg 36 - too old 24 - just right Hard to forget the firing order now. The previous owner has the wires going to the wrong cylinders...My car should be running much better in about 45 seconds Thanks again Captain Carl... Link to comment Share on other sites More sharing options...
sblake01 Posted March 7, 2005 Share #4 Posted March 7, 2005 I hope that solves the problem you were having with the car running badly while warming up. I am surprised that it even ran well when warm with the wires out of sync. Let us know how it turns out and if that cold running problem goes away with the wires corrected. Link to comment Share on other sites More sharing options...
kcdc Posted March 7, 2005 Author Share #5 Posted March 7, 2005 I was wrong about the plug wire's going to the wrong cylinders; not sure how I miss read them previously. Everything is right from the Dist. Cap to the cylindersO well at least I learned the cylinder numbering. Link to comment Share on other sites More sharing options...
jwheless23 Posted March 10, 2011 Share #6 Posted March 10, 2011 can someone put the picture up again? its not showing up. thanx Link to comment Share on other sites More sharing options...
FastWoman Posted March 13, 2011 Share #7 Posted March 13, 2011 15 - too youg36 - too old 24 - just right Hard to forget the firing order now. Or for older folks... 62 = too old 41 = too young 53 = just right Link to comment Share on other sites More sharing options...
Fire604 Posted November 29, 2011 Share #8 Posted November 29, 2011 If anyone has the pic and could post it, I would appreciate it. Link to comment Share on other sites More sharing options...
240260280z Posted November 29, 2011 Share #9 Posted November 29, 2011 Link to comment Share on other sites More sharing options...
DeesZ Posted December 4, 2011 Share #10 Posted December 4, 2011 as seen on a '72... Link to comment Share on other sites More sharing options...
Steves Posted December 4, 2011 Share #11 Posted December 4, 2011 There is only ONE firing order. 153624 Period.And this is true for ALL straight sixes. Gas, diesel, any make, any application. Link to comment Share on other sites More sharing options...
sblake01 Posted December 4, 2011 Share #12 Posted December 4, 2011 (edited) -double post, sorry- Edited December 4, 2011 by sblake01 Link to comment Share on other sites More sharing options...
