Posted March 13, 200519 yr comment_116511 Hello!I have noticed that the roof of my interior is pretty dusty especially around the edges, and really could do with a good clean. Apart from taking the whole thing out to clean, is there any particular method you'd use so that you get a decent enough force while not stretching the material.I know, sounds simple enough just to use water and a cloth, but I thought there could be a trick to it . . . :cross-eye Link to comment https://www.classiczcars.com/forums/topic/15284-cleaning-the-roof-interior/ Share on other sites More sharing options...
March 13, 200519 yr comment_116519 Hey Lachlan,I have found the best approach is with "Nifti". Spray it on and let it soak for 5 to 10 minutes. Do it in the shade too. If you need to scrub a little, use a light brush or even a tooth brush. Then wipe off with a wet cloth, making sure to rinse it regularly. Link to comment https://www.classiczcars.com/forums/topic/15284-cleaning-the-roof-interior/#findComment-116519 Share on other sites More sharing options...
March 13, 200519 yr comment_116521 I'd be very careful about scrubbing that 30+ year old headliner. It is for that very reason that I no longer have the original one in my 810 and am still in search of an upolstery shop that has a similar material and the skills to properly install it! Link to comment https://www.classiczcars.com/forums/topic/15284-cleaning-the-roof-interior/#findComment-116521 Share on other sites More sharing options...
March 13, 200519 yr comment_116527 I think I would just wipe it very lightly with a dry microfiber cloth, the foam behind the vinyl is 30plus years old to very suseptable to the crumblies!Will Link to comment https://www.classiczcars.com/forums/topic/15284-cleaning-the-roof-interior/#findComment-116527 Share on other sites More sharing options...
March 13, 200519 yr comment_116549 I think I would just wipe it very lightly with a dry microfiber cloth, the foam behind the vinyl is 30plus years old to very suseptable to the crumblies!WillYeah, I know that now :stupid: Link to comment https://www.classiczcars.com/forums/topic/15284-cleaning-the-roof-interior/#findComment-116549 Share on other sites More sharing options...
March 14, 200519 yr Author comment_116614 Thanks guys, I'll try that! Link to comment https://www.classiczcars.com/forums/topic/15284-cleaning-the-roof-interior/#findComment-116614 Share on other sites More sharing options...
