Posted March 15, 200520 yr comment_116872 Hi guys, im planning to use KONIs for my Z but the mechanics told me that i need to replace my rear suspension housing with the original ones, the question is what is a suspension housing?and where can i get one? Thanks Guys Link to comment https://www.classiczcars.com/forums/topic/15310-koni-question/ Share on other sites More sharing options...
March 15, 200520 yr comment_116893 His statement (as written) doesn't make sense. Link to comment https://www.classiczcars.com/forums/topic/15310-koni-question/#findComment-116893 Share on other sites More sharing options...
March 15, 200520 yr comment_116899 Hi guys,im planning to use KONIs for my Z but the mechanics told me that i need to replace my rear suspension housing with the original ones, the question is what is a suspension housing?and where can i get one? Thanks Guys Are you saying your rear suspensione has been modified beyond a stock setup? I'm guessing here, that what your mechanic is calling a suspension housing, is the strut housing assembly. I don't believe you will need to change yours out, but you will need to figure out what length insert (shock) you need. Do some searching of the archieves for more definite answers to your question...the answers are there! Link to comment https://www.classiczcars.com/forums/topic/15310-koni-question/#findComment-116899 Share on other sites More sharing options...
