Posted March 17, 200520 yr comment_117187 I am looking for a set of +.5mm pistons for a "LZ22S" Nissan. What is it? A truck? Euro model? Japanese Model? Help me out here guys. Link to comment https://www.classiczcars.com/forums/topic/15338-what-is-a-lz22s-need-a-set-of-pistons-from-this-nissan/ Share on other sites More sharing options...
March 17, 200520 yr comment_117201 I'm not sure on this but I believe the "NAPS Z" engine is what you're after. It was in some 200SX models in the 80's. Around 82-83 I think. Was called a Z22E if I recall correctly. Good Luck, Chris Link to comment https://www.classiczcars.com/forums/topic/15338-what-is-a-lz22s-need-a-set-of-pistons-from-this-nissan/#findComment-117201 Share on other sites More sharing options...
March 17, 200520 yr comment_117208 I believe that the Z22S would have been the carbureated version that was in the pickups in the early eighties. I don't think we got the Z22E here. The only NAPS Z engines I reacall here are the Z20S, the Z22S, and the Z24S. I don't remember ever seing that engine in the fuel injected (E) form. Someone correct me if I'm mistaken. (Like they wouldn't?) :classic: Link to comment https://www.classiczcars.com/forums/topic/15338-what-is-a-lz22s-need-a-set-of-pistons-from-this-nissan/#findComment-117208 Share on other sites More sharing options...
March 17, 200520 yr comment_117224 I checked this site and he said Z22E also. So maybe he and I are both wrong. He owned one, although he was 16. http://www.v6-s12.com/History.htmChris Link to comment https://www.classiczcars.com/forums/topic/15338-what-is-a-lz22s-need-a-set-of-pistons-from-this-nissan/#findComment-117224 Share on other sites More sharing options...
March 17, 200520 yr comment_117249 ZSaint you were asking about the "LZ22S" here is a link to info about the LZ engines that were produced by Nissan for racing, not sure if that is what engine you are talking about as Nissan did create the L Series, Z Series and the LZ Series (race only I believe)LZ Twin CAMS Also see this link for a list of factory engines produced by Nissan/Datsun/Prince does not include special heads like the LZ twin cam or the LY six cylinder cross-flow headsNissan/Datsun/Prince Engines Link to comment https://www.classiczcars.com/forums/topic/15338-what-is-a-lz22s-need-a-set-of-pistons-from-this-nissan/#findComment-117249 Share on other sites More sharing options...
March 18, 200520 yr Author comment_117301 I found the info I needed on this engine. It came in a 720 pick-up truck between 6/80 and 10/82. It was 87mm stock and came with a long rod. (S designation) These piston will work on the L6 engines with the LD28 crank. They will provide 9.4 cr with the P90 head. I am trying to order a set of +2 (87.5) pistons for my engine. I will let you know my results and what they cost. Link to comment https://www.classiczcars.com/forums/topic/15338-what-is-a-lz22s-need-a-set-of-pistons-from-this-nissan/#findComment-117301 Share on other sites More sharing options...
March 23, 200520 yr Author comment_118103 I ordered the pistons from the Nissan Dealer. The cost is $57 @ plus rings. They have 5 but they have to order one. I hope it is the same piston. Some times you get a different "batch" and you cannot get them to balance. Link to comment https://www.classiczcars.com/forums/topic/15338-what-is-a-lz22s-need-a-set-of-pistons-from-this-nissan/#findComment-118103 Share on other sites More sharing options...
March 23, 200520 yr comment_118118 Do you know the pin height of this piston? Link to comment https://www.classiczcars.com/forums/topic/15338-what-is-a-lz22s-need-a-set-of-pistons-from-this-nissan/#findComment-118118 Share on other sites More sharing options...
March 24, 200520 yr Author comment_118177 I used the chart that allows you to "build" a L6 engine. You punch in the various options (block, rod, head, head gasket and piston) This piston is the only one that offers 9.4 cr. It must have a dome on it or uses a shorter rod. I just hope this works like the formula states. Link to comment https://www.classiczcars.com/forums/topic/15338-what-is-a-lz22s-need-a-set-of-pistons-from-this-nissan/#findComment-118177 Share on other sites More sharing options...
March 24, 200520 yr comment_118285 ZSaint said: I used the chart that allows you to "build" a L6 engine.Where can I find this?Also, I would still like to know the pin height of the piston LZ22 if anyone knows. This would tell me the installed piston height (piston/deck ratio).So, you used the diesel crank (LD28) and stock rods?And the pistons were .5mm over bore (87.5mm)? I'm trying to figure your final displacement. Link to comment https://www.classiczcars.com/forums/topic/15338-what-is-a-lz22s-need-a-set-of-pistons-from-this-nissan/#findComment-118285 Share on other sites More sharing options...
March 25, 200520 yr Author comment_118351 I have a set of 240 rods. The bore is 87.5 and I have a LD 28 crank. What is my engine size? Link to comment https://www.classiczcars.com/forums/topic/15338-what-is-a-lz22s-need-a-set-of-pistons-from-this-nissan/#findComment-118351 Share on other sites More sharing options...
March 25, 200520 yr Author comment_118352 I am hoping this piston for the LZ22S engine has short rods. That is the only way a person can get a 9.4 cr with this long rod and large combustion chamber. I will see what the pin height is after the pistons arrive. EN1 know what these pistons have for a pin height? Link to comment https://www.classiczcars.com/forums/topic/15338-what-is-a-lz22s-need-a-set-of-pistons-from-this-nissan/#findComment-118352 Share on other sites More sharing options...
