Just wanted to clear up a few questions I had relating to proper coil operation.
When the key is on "ON" but the engine not going, power should be going into the + of the coil. Should current flow between the + and - of the coil without the engine on? Should it flow between the + of the coil and the chassis ?
When the Coil is firing the current between the + and - of the coil should be "pulsating" right?
Thanks, just trying to sort out why my car has no spark (distributor and coil are fine).
Current will flow between + - if the points are closed. With the points open you should be able to measure 12V between + and chassie ground. If your condenser is shorted you will have no spark and will measure less than 12V from coil + to ground.
Yes it will be but the period will be very short and probably can not be seen using a digital voltmeter, an analog meter would show it better.
No spark if you have 12V to the coil (and haven't done anything like swap distributors) would be usually :
Bad condenser
bad/slipped points
bad coil (usually they leak oil from the hi tension lead area when bad)
Thanks LanceM. Turned out my problem was that I had a chassis earth at - coil (didnt realise I wasnt supposed to...).
TomoHawk, that sounds like it would be a very nice setup, a little more sophisticated than my Pencil tester :nervous:
You're right. Using the scope, you can see when the points open & close, so you can tell if the points are bad, and other stuff. I should hook it up to the electronic dizzy on the Z, and read up on what the line should look like.
