Am new at this! I just bought a 1976 280Z and need to repair and replace a few things on it, I need to know where I can find a Hazard Switch that goes onto the shift console. If anyone can help, message back or e-mail me please!
thx.
lockandloadandready@yahoo.com
https://www.classiczcars.com/forums/topic/15416-need-help-finding-parts/
Watch EBAY Motors or if you get stuck order the ZCAR CD from this website and use NISSMO http://www.nismoparts.com they can get alot of OEM part, I've found them to be very helpful. Also try Victoria-British http://www.victoriabritish.com also very good but on the expensive side I think. There are a number of others but this get you going. I highly recommend you get the ZCAR CD and a Nissan factory service manual. My 2 cents
I probably have one but it's for a 78. My stuff is boxed up because we're moving this weekend but I'll know for sure early next week. I don't know if the switch for a 78 is different than a 76. Where are you located?
thx.! I called Victoria British and could not help? I called dealers and could not help? this sucks! there is something missing inside the switch, the rocker moves freely back and forth and not contacting the metal tabs inside causing no turn signals.I live in Tracy Ca.
Not to worry I got one from NISSMO for my 74 260z. Set up an account with them doesn't cost any thing. I looked at my CD came up with the following part numbers (P/N) for a hazard switch 25910-N3600 good from 12/74 to 7/76 and 25910-N4700 8/76 to unknown. When was your Z manufactured?
:classic:
thanks for the info! it was manufactured on 7/76 on the side door panel, this has been a big help! what happen was the guy who I bought it from had installed a sterio and disassembled the switch to get it out (Idiot!) he lost something inside the switch that pushes the contact tabs? let me try ordering this and see what happens?
TTK
From what I can determine the 75-76 switch is the same as the 77-78 switch except for the connector. If you can't find one maybe you could change the connector on one of mine. Let me know, I'd give it to you for the cost of postage.
thx! What I did is I disconnected the wiring harness and jumped the wires on the connector to make the turn signals work for know. It looks like a simple 4 pole switch, I will let you know
thx again!
