Jaguar XJS ZEBRANO WOOD SHIFT KNOB
SJGREEN71
Hey Everbody,
I just bought this shift knob on eBay, and I am hoping it is going to work with my '71 series 1 240Z. It seems to have the proper 8mm X 1.25 threading. An old post on this forum says that some Jaguar knobs will work. This one is the MOMO OEM knob from the XJS. AT $39 it is no more expensive than many aftermarket knobs for the Z, and it looks a whole lot better.
Ebay item # 7963603602
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7963603602
Hello again,
I got the shift knob today and the knob part fits perfectly. Very nice quality wood and finish. Too bad Momo doesn't make this kind of suff any more. Anyone who is interested in a wood knob for the Z should be encouraged to look at what is available for the XJS.
My only problem is that there is no room for the finishing piece (shown just below the knob in the picture). Any ideas on how to get it to fit? The knob part consumes the whole 1.25 " of the threaded part of the shift lever leaving no room for the finishing piece that is a little over 3/4 inch. The finishing piece is made of black metal and is threaded in the same 8mm as the knob.
Hi
This is just an idea. I was thinking about the trim ring, and how it's 3/4"
in height you. If you take a drill that is .015" larger in diameter then your shifter shaft, and you drill a counterbore into your trim ring from the bottom, leaving a 3/16" of thread at the top. The trim ring will sit down lower on the shifter shaft and will only take up 3/16" of your total thread height. Make sure to protect your finish on the trim ring when you drill. here's a drawing of what I mean
THIS IS ONLY AN IDEA, DISREGUARD IT AT YOUR WILL.
Ahmed
  • Who's Online   0 Members, 0 Anonymous, 371 Guests (See full list)
