Central Locking
Aussie260z
Ahhhhhhhhhhh!
when you are trying the central locks for fit, youre looking at the outside door handle arent you!
Try the inside door handle (bottom of door away from window and other moving parts) all the locking rods are there to attach to and its an easy fit!
cheers
This is just not working out............
I pulled the door trims of and gave it another go,
I think i understood the directions given, but.........
I bolted the actuator underneath the lock which looks as if it controls the inner door handle,
But couldnt quite get a decent enough hold onto the lock to get it work properly - i managed to get it to close, but it wouldnt pop back up again,
Think some pics would make this a lot easier...............
Just couldnt get around connecting up the actuator with the door lock - there just wasnt anything in the Central Locking kit that was suitable
  • Who's Online   1 Member, 0 Anonymous, 423 Guests (See full list)
