I have my car on the rotisserie. I have it upside down and all of the rear supspension is on. The R200 is also bolted in the car. I have shortened the outer drive flanges 3/4" each. I now have an additional 1 1/2" of travel over the stock ZXT set-up. What is the best way to install these axles? I can take the shock tower out of widen the space until the axles are bolted in. I can then insert the towers back into the 3-holes and the rear supension is done, correct? Or, is there a better way to put these axles in. I await your responses.
