Email logins are now active ×
Just Brought Home A 72 240z
Matt.L
Hi everyone,
I just bought a 72 240z 4 speed from the original owner. I was wondering some estimated proformance figures on it, the L24 motor is running the following..
- Twin SU carbs rebuilt recently
- stage 1 or 2 cams (redone with the head the same time as the carbs)
- Motorsport Header
- 2 1/4 all the way back exaust
Thanks in advance
Factory rating (100% Stock) was 150 HP, a header by itself won't get you anything; but with a mild cam and the header you should be in the low to (possibly) mid 160 HP range IF everything is set up properly (Carbs, Ignition, Rings and bottom end of the motor in good nick) .
* all figures at the flywheel
  • Who's Online   2 Members, 0 Anonymous, 143 Guests (See full list)
