Gearing calculation: someone check my math PLZ
EricB
Here goes:
My rear tires are 225/50R15 that comes out to a 23.86" diameter
I've got a loaner original 4spd from Victor Laury (thanks Victor!) so 4th gear is a 1.00 ratio. My rear end right now is a 4.11
At what feels like a slow freeway cruising speed and observing a steady 4000rpm I calculate I am actually travelling at 69mph. "Feels" right since everyone in L.A. including the CHP does at least 75-80mph on the freeway regardless of the 65mph speed limit.
(rpmxtire diameter)/(final ratioxtrans ratiox336)=mph
(4000X23.86)/(4.11X1.00X336)=69.xxmph
When I get my 81-3 5spd back with an 0.745 ratio 5th gear from rebuild I've been toying with the idea of putting in a 4.375 final drive. At the same revs my speed would actually increase to 87mph???
(4000x23.86)/(4.375x0.745x336)=87.14mph
Did I do the math right?
-e
Hey Eric, it may be possible that the 4 spd you have came out of my 1970 240Z. A few months ago Victor drove up to my place and I traded the 4 spd for a case of Pacifico beer. He was pretty happy with the deal. Also, if you visit most any of the big tire outfit online, they have the calculation formulasto figure out your speed...just type in the info and it will calculate it for you.
I got the tire diameter from the info section on discounttires.com
I got the mph formula from a rock crawler website.
I just want to make sure I plugged all the numbers in the right way in the right units. It just seems crazy that the combination of the lower 4.375 (vs the 4.11) and the 5spd would yield a higher cruising speed for a given rpm.
If you asked for a case of Pacifico, any idea what Victor drinks so I can go drop off a case at his place? He gave it to me before Xmas and I lagged putting it on as my wife and I spent nearly every weekend for almost 6mo looking for our first house.
Needless to say we found it in the end. :)
-e
I have the 83 5 sp and a 4:37 rear R200. I use the car for autox and street driving (mostly on the weekends). If it is your daily driver I would stay with the 4:11. The 4:37 is very low. I go through 1st very fast with 23.75 diameter tires. I think the solution for me is taller tires (25", 205/60/15 or 205/55/16) then I can have better gearing for the steet and still have the low gearing on the track with the autox tires. Right now my speedo is around 90 when I am going 65 becauise I have a 3.70 speedo cog and the smaller diameter tires. I think 75 is around 3700 RPM.
  • Who's Online   1 Member, 0 Anonymous, 577 Guests (See full list)
