Posted May 2, 200519 yr comment_122397 I'am currently thinking about buying a 240z. Does anyone know the stock height of a 240z, also the length. Whats lowest height anyone has lowered their car? And do you know what the curb weight of the car is? thank you Tom Link to comment https://www.classiczcars.com/forums/topic/15784-how-tall-is-your-240z/ Share on other sites More sharing options...
May 2, 200519 yr comment_122398 Its a about 2400 pounds i think..... Link to comment https://www.classiczcars.com/forums/topic/15784-how-tall-is-your-240z/#findComment-122398 Share on other sites More sharing options...
May 3, 200519 yr comment_122428 The weight depends on the year of the Z . My '73 is 2650 with a half tank and me in it. So 2430 . The height of the front is 23 1/4'' from the tip on the hood at the upper edge , to the ground. Link to comment https://www.classiczcars.com/forums/topic/15784-how-tall-is-your-240z/#findComment-122428 Share on other sites More sharing options...
May 3, 200519 yr comment_122433 G'Day Tom,According to my Haynes manual, the Zed's dimentions are; 240Z 260Z 260Z 2+2Overall length ............ 165.2 in 169.1 in 180.9 in 419.6 cm 419.4 cm 459.5 cmWidth ....................... 64.1 in 64.1 in 64.9 in 162.8 cm 162.8 cm 164.9 cmHeight ...................... 50.5 in 50.6 in 50.8 in 128.3 cm 128.5 cm 129.0 cmWheelbase ................ 90.7 in 90.7 in 102.6 in 230.4 cm 230.4 cm 260.6 cmWeight UnladenManual Gearbox .......... 2350 lbs 2499 lbs 2669 lbs 1043 kg 1134 kg 1210 kgAuto Trans. ............... 2400 lbs 2509 lbs 2679 lbs 1089 kg 1134 kg 1215 kgDon't ask me how come the 260 is longer than the 240 is in inches, yet manages to be bloody SHORTER in cm's. :stupid: :stupid: :stupid: Obviously a typo I double checked the book, that's what is printed.Hope that's of some help to you Tom,Rick. Link to comment https://www.classiczcars.com/forums/topic/15784-how-tall-is-your-240z/#findComment-122433 Share on other sites More sharing options...
