May 5, 200519 yr comment_122621 My compression right now is 80 80 80 80 100 100 If your compression is that low, why are you worring about oil and such? It's time to tear that engine apart and rebuild it. Any compression below about 140 lbs/sq indicates worn piston rings. Compression is typically between 180 (factory spec) and 150. Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=2#findComment-122621 Share on other sites More sharing options...
May 5, 200519 yr Author comment_122623 Thats what I was thinkingI have another motor which should be good, but I'd like to run this one untill I get organised to swap. Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=2#findComment-122623 Share on other sites More sharing options...
May 5, 200519 yr comment_122635 I was reading the info on a can of Liquid Wrench™ and it suggests that you put in some before you change the oil. It's supposed to thin the oil a little, and helps more of the crud get out of the engine. It sounds like a few treatments of that would really clean out the engine.thx Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=2#findComment-122635 Share on other sites More sharing options...
May 5, 200519 yr comment_122640 I hear substituting 1 quart of atf instead of engine oil will break it down good over time instead of clogging the pick up screen. Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=2#findComment-122640 Share on other sites More sharing options...
May 5, 200519 yr comment_122642 ^^would that be good for an engine, though? Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=2#findComment-122642 Share on other sites More sharing options...
May 5, 200519 yr comment_122647 You don't want to run your engine with the thinned oil for long. Usually you put some in for a short time before you change the oil. Go to the store and read the package. Maybe it's on their website. Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=2#findComment-122647 Share on other sites More sharing options...
May 5, 200519 yr comment_122665 I was reading the info on a can of Liquid Wrench™ and it suggests that you put in some before you change the oil. It's supposed to thin the oil a little, and helps more of the crud get out of the engine. It sounds like a few treatments of that would really clean out the engine. This is the most idiotic thing that I have read on this web sight . Shure just pore some gasoline in the engine, we all know how gas will clean grease off our hands . Then light a match over the valve cover inlet and watch the fire works ! For crying out load , if you have an old tired engine that is showing such low compression , leave it alone untill you can do a rebuild . Just change the oil and don't abuse it . Other wise you will be walking insted of riding. Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=2#findComment-122665 Share on other sites More sharing options...
May 5, 200519 yr comment_122691 Who wants you to pour (not pore) gasoline in your engine???the Liquid Wrench people say that adding an amount ( read the directions) of their product to your oil before an oil change will benefit. See product for details.thx Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=2#findComment-122691 Share on other sites More sharing options...
May 5, 200519 yr comment_122692 His response may have been a bit tounge-in-cheek (don't correct people's spelling, we all know what he means), but the point Gary makes is valid. Leave it alone. A high mileage, low compression, and in other words tired engine does not need the sludge cleaned out of it. It will only lead to further problems. The engine needs to be rebuilt or replaced which is what the author of this thread is contemplating anyway. He's just looking for a way to keep it going for a while. Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=2#findComment-122692 Share on other sites More sharing options...
May 5, 200519 yr comment_122728 I was reading the info on a can of Liquid Wrench™ and it suggests that you put in some before you change the oil. It's supposed to thin the oil a little, and helps more of the crud get out of the engine. It sounds like a few treatments of that would really clean out the engine.thxNOT!!!! :stupid: Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=2#findComment-122728 Share on other sites More sharing options...
May 5, 200519 yr comment_122739 You may want to skip the oil and filter change altogether. Just keep oil in the ole gal. I wouldn't put high detergent oil in an old sludged up motor. Try to find some non detergent. It'll keep everything slippery and that's all you want until you build a new engine. Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=2#findComment-122739 Share on other sites More sharing options...
May 5, 200519 yr comment_122740 Before you criticize the idea, why don't you contact the Liquid Wrench people and get their view on why it's on the can? Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=2#findComment-122740 Share on other sites More sharing options...
