May 5, 200519 yr comment_122743 TomoHawk said: Before you criticize the idea, why don't you contact the Liquid Wrench people and get their view on why it's on the can?Tomohawk, you obviously don't understand the point here! By attempting to loosen or remove any of the built up sludge will result in problems, as noted from people with real life experiences! Liquid Wrench just wants you to buy their product. The stuff is a solvent for gawd sakes!!! :stupid: Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=3#findComment-122743 Share on other sites More sharing options...
May 5, 200519 yr comment_122746 Here's what it says on the can: "Bonus Uses: --To quiet noisy valve lifters, add 8 oz. to crankcase oil. --To dissolve sludge tars, gums and residues, add one pint to crankcase oil 150 miles before oil change. Drain oil, change oil filter cartridge. Refill with fresh oil and add Motor-Medic No.1 for improved performance." I just use it on rusty bolts & nuts. If you have been reading the comments on this topic, you would have noticed that I'm not recommending or even suggesting to anyone that they should use it. The Liquid Wrench people suggest it. And it's a "Quality American Product" thx Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=3#findComment-122746 Share on other sites More sharing options...
May 5, 200519 yr comment_122755 If you are not suggesting that someone use it, why on earth would you even post it? Tomohawk, you will never change will you!? I don't know why I even bother responding to your nonsense! :disappoin Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=3#findComment-122755 Share on other sites More sharing options...
May 6, 200519 yr comment_122775 you guys you guys...... Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=3#findComment-122775 Share on other sites More sharing options...
May 6, 200519 yr comment_122776 Mr. Derrick072 mentioned substituting a quart of ATF for oil, and you didn't pick up on that? I didn't take it as a suggestion, and I'm sure he mean it as one. That's the attitude more people need- and less presumptions.Sometimes, information is just information.thx Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=3#findComment-122776 Share on other sites More sharing options...
May 6, 200519 yr comment_122783 SEAFOAM works Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=3#findComment-122783 Share on other sites More sharing options...
May 6, 200519 yr comment_122788 SEAFOAM is a good product. I wanna try it this summer myself.However, I have been told by service techs in my area, that using it is not recommended unless you have the equipment to capture the smokey-stuff that comes out of the tailpipe. I'll go out to the farm to do my engine.Spudea-It's funny you brought up Seafoam. Mr. UhOh7 was asking about removing the sludge from the oil and varnish from the inside of the engine. Seafoam is supposed to be used to treat carbon buildup on the intake,valves,heads, etc. Why did you mention Seafoam? Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=3#findComment-122788 Share on other sites More sharing options...
May 6, 200519 yr comment_122796 "When Added to Crankcase (Oil)1.Frees sticky lifters and rings 2.Increases R.P.M.'s vacuum and compression 3.Cleans dirty parts 4.Removes moisture 5.Cleans PCV valve systems6.Cleans dirty engine parts internally by removing harmful gums, varnish and carbon. WORKS AND PERFORMS INSTANTLY."From the product site and you can read it on the bottle. Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=3#findComment-122796 Share on other sites More sharing options...
May 6, 200519 yr comment_122799 Try substituting a quart of Marvel Mystery oil for a quart of oil, and use the Rotella oil from shell(available at Walmart)- this suggestion is my part of a thread from about a year ago.Will Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=3#findComment-122799 Share on other sites More sharing options...
May 6, 200519 yr comment_122836 Ah, Marvelous Mystery Oil...... We tried to analyze it in the lab once or twice... Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=3#findComment-122836 Share on other sites More sharing options...
May 6, 200519 yr comment_122854 Ok Tomo, Get out of the plastic sheets and marvel Mystery Oil, give them a bath, and put them back in Carl's garage! That "Ah" and " " just had too much enjoyment in them... Will Link to comment https://www.classiczcars.com/forums/topic/15798-internal-engine-cleaner/?&page=3#findComment-122854 Share on other sites More sharing options...
