changing differential oil
You are correct; use a 1/2 drive ratchet/breaker.....I don't know of any other tool that works well on a real tight diff plug on a zed....if usings a 1/2" ratchet, make sure its a heavy duty one, because yes, you could trash it, sometimes these are on tight, and like I said previously, make the ratchet longer for leverage.
  • 11 years later...
