May 10, 200618 yr Author comment_167063 Enjoy | #15Stream: http://www.voodoo-people.com/~daz/mull/wmv/mull@hugo15.wmv Link to comment https://www.classiczcars.com/forums/topic/15918-my-71-240z-project/?&page=9#findComment-167063 Share on other sites More sharing options...
May 11, 200618 yr comment_167089 another sweet video. its comin along nicely. Link to comment https://www.classiczcars.com/forums/topic/15918-my-71-240z-project/?&page=9#findComment-167089 Share on other sites More sharing options...
May 19, 200618 yr Author comment_168034 Today I picked up some stuff from sand blasting. Powder coating awaits. Link to comment https://www.classiczcars.com/forums/topic/15918-my-71-240z-project/?&page=9#findComment-168034 Share on other sites More sharing options...
June 30, 200618 yr comment_172854 Hello MullI discover your video recently, what amazing works!!!!I start a restauration project to built an Historic 240Z racing car, as i am mechanic teacher, i will do the project with my students and was help by a friend which is bodywork teacheri will show him those video, i think it will be very interested by them and me probably show them to our student!!!A question: I notice you speak about powdercoating, anyone could explain me what is it exactly because we didn't know that in France, and how it is spray, what is the advantage?Thank youBen Link to comment https://www.classiczcars.com/forums/topic/15918-my-71-240z-project/?&page=9#findComment-172854 Share on other sites More sharing options...
June 30, 200618 yr comment_172855 From what I understand. Powder coating is this.The item you want to powdercoat is celaned off to bare metal, then heated to a hot temperature.Then the coating which is some sort of plastic powder is applied and melts on to the surface to form a paint like coating.Thats about all i know on the subject, so maybe some powdercoaters could chime in. Link to comment https://www.classiczcars.com/forums/topic/15918-my-71-240z-project/?&page=9#findComment-172855 Share on other sites More sharing options...
July 1, 200618 yr comment_173012 Your dedication and love for this 240Z says you need to be comended and you should copyright your video. Looking forward to seeing its progress, nice to see you using the finest Sikkens on it! Link to comment https://www.classiczcars.com/forums/topic/15918-my-71-240z-project/?&page=9#findComment-173012 Share on other sites More sharing options...
July 5, 200618 yr comment_173438 This project is so awesome and your documentation of it takes it to a new level! Very enjoyable videos. Link to comment https://www.classiczcars.com/forums/topic/15918-my-71-240z-project/?&page=9#findComment-173438 Share on other sites More sharing options...
July 5, 200618 yr comment_173440 Mull, how's the carbon dash and center console going along? Link to comment https://www.classiczcars.com/forums/topic/15918-my-71-240z-project/?&page=9#findComment-173440 Share on other sites More sharing options...
July 5, 200618 yr comment_173477 You mention bad luck with Tabco, I have had very good service from a company called mill supply for steel body panels. Link to comment https://www.classiczcars.com/forums/topic/15918-my-71-240z-project/?&page=9#findComment-173477 Share on other sites More sharing options...
July 5, 200618 yr comment_173511 Question: If you are using lead soldering (excellent videos BTW), can you use the lead as a bonding agent as well? For example, I have a dent in nearly the exact corner as you've repaired in the photo (driverside rear). If I found a piece of panel, could I use the lead to "weld" in the piece instead of actually welding it then leading it? It looked as if that was what you did with the gas filler lid, or am I mistaken? Link to comment https://www.classiczcars.com/forums/topic/15918-my-71-240z-project/?&page=9#findComment-173511 Share on other sites More sharing options...
July 5, 200618 yr comment_173514 Ricklandia said: Question: If you are using lead soldering (excellent videos BTW), can you use the lead as a bonding agent as well? For example, I have a dent in nearly the exact corner as you've repaired in the photo (driverside rear). If I found a piece of panel, could I use the lead to "weld" in the piece instead of actually welding it then leading it? It looked as if that was what you did with the gas filler lid, or am I mistaken?He welded the gas lid, only used lead to smooth the area over.Lead is very soft by metal standards and would have hardly any strength to hold parts together. Epoxy would probably be stronger than lead, but getting it welded is the best thing to do. Link to comment https://www.classiczcars.com/forums/topic/15918-my-71-240z-project/?&page=9#findComment-173514 Share on other sites More sharing options...
July 6, 200618 yr Author comment_173591 First off, thanks for all the positive feedback - all of you! : ) theianmonster said: Mull, how's the carbon dash and center console going along?The dash is currently on hold - chassis is still number one priority. The centerconsole will get it's modifications once I have the dash. Right now pretty mucheverything is put on hold I'm sorry to say. People helping me are busy, etc. At the end of july/middle of august the car will get its rear custom flares andit'll also be shipped off to have a custom 12 (or more) point roll cage fitted. All in due time ... :classic: Link to comment https://www.classiczcars.com/forums/topic/15918-my-71-240z-project/?&page=9#findComment-173591 Share on other sites More sharing options...
