ballast resistor getting hot
helopilot
Put a new ballast resistor on the car today. It worked great for a bit then the car died like a switch had been thrown. Felt the BR and it felt fairly hot. The car sat for a while and then it started back up. Did the same thing over again. Any ideas? Car has new cap rotor points condenser. Additionally I have put a new alternator and voltage regulator.
Check the voltage at each end of the ballast resistor (BR). Put the black lead of your volt meter (VM) to a solid ground on the chassis, and put the red lead on one end of the Ballast. Write down the reading you get, then move the red lead to the other end of the BR (while keeping the black lead of the VM grounded) and write down the reading you get there. The higher reading is the input voltage TO the BR, the lower reading is the output voltage FROM the BR
  • Who's Online   1 Member, 0 Anonymous, 620 Guests (See full list)
