HID headlights
chickenwafer
But for $20 bucks, I don't think I can loose
You're probably right - provided that your fusebox doesn't melt since you're now pumping about twice the wattage as stock (which is 40 watts on low and 55 on high if I recall correctly).
Since installing Dave's upgrade harness I switched the stock 20A headlight fuses to 2A fuses. Seriously, feel how hot your fusebox is getting with these new headlights.
escanlon installed the wireing loom that Dave makes and I think it increased his brightness by 40% . Dash lights and tail lights as well . Just installing the new wireing . I have the same set up in my Z but I havent powered it up yet. I did install the high wattage bulbs , Krypton 90s I think . With only about 5 amps going to the switch all should be good.
  • Who's Online   0 Members, 0 Anonymous, 625 Guests (See full list)
