Posted May 18, 200519 yr comment_124371 Can anybody tell me what kind of petrol does a 240 need? Leaded or unleaded. This particular car is a 1972 US 240Z with a complety stock engine. At the moment i'm using an lead-alternative to enrich the petrol, just to be on the save side, but it is pretty expensive stuff, and when the engine doesn't need it I will be glad to get rid of it.ThanksEmil Link to comment https://www.classiczcars.com/forums/topic/15959-leaded-or-unleaded/ Share on other sites More sharing options...
May 18, 200519 yr comment_124403 I use unleaded pump gas (93 octane) in my bone stock 72 240Z. Seems to run fine.Vicky Link to comment https://www.classiczcars.com/forums/topic/15959-leaded-or-unleaded/#findComment-124403 Share on other sites More sharing options...
May 18, 200519 yr comment_124413 I likewise use premium (93 octane) in mine. As mine is bone stock and original with quite a few miles on it, I add a lead substitute to the tank at every fill. The original valve seats are not hardened and will not last as long as the new hardened seats usually installed on a rebuild while using unleaded fuel. The original engines required leaded fuel..I have used lead substitute for the past 20 years and have 167,000 miles on the original engine with lots of power....OK ...I'm ready for the comments. I have my asbestos pants on! Link to comment https://www.classiczcars.com/forums/topic/15959-leaded-or-unleaded/#findComment-124413 Share on other sites More sharing options...
May 19, 200519 yr comment_124422 OK. Wouldn't it have been cheaper in the long run to just install hardened valve seats rather than pay for lead substitute additive at every fill up for 20 years? Link to comment https://www.classiczcars.com/forums/topic/15959-leaded-or-unleaded/#findComment-124422 Share on other sites More sharing options...
May 19, 200519 yr comment_124512 This was just discussed...try searching for the other thread...there was a lot of info in it. Link to comment https://www.classiczcars.com/forums/topic/15959-leaded-or-unleaded/#findComment-124512 Share on other sites More sharing options...
