Hi all,
I have the tranny out of my 240z (an '83zx 5sp) and want to change out all of the oil. I've seen a couple different capacity levels listed for filling.
Is 3 1/8 pints an accurate capacity level for refilling?
thanks
Bill Oakes
Libertyville, IL
As long as you have enough gear lube on hand, just fill the tranny until it comes out the fill plug hole...just like filling a differential. I believe the FSM provides transmission lube capacities.
