Absolute Z Club BBQ in Long Beach, Ca
Beerbrawler
After leaving the previous post earlier this morning, I got to thinking why not do it now. I've had the parts for over a year so I left the computer and four hours later, I had working a/c! Nothing was wrong with the system itself but one of the plastic levers in the heater/ac control panel was broken and I couldn't close the vent unless I reached under the dash and did it manually. That plus the fact that the switch that turns the compressor on and off was stuck in the on position so I had it disconnected. It was kind of a tedious job since the console and the center dash panels have to be removed in order to replace the control panel and the switch. I relocated the switch from the console to below the guages to the right of the ignition switch. After having no a/c for better than a year it still reaches 40 degrees at the vents! So, now that that's done, I'll see those of you who are going in Long Beach next month.
I installed new heater and a/c controlls. Pull my system down, ditched the R12, replaced some seals and o rings, and recharged it with R414B (Hotshot). It'll cool down to 32.1 deg. at the vents on high! I'll be there, riding in confort.
cool, i'm tryin to get my exhaust back on...i ran out of wire for my welder and went to get more, Harbor frieght was out of the stuff i usually get, the dude at the counter said this other stuff would work, well it didnt(like i thought) so now i get to go back, i need to finish this job up today!
  • Who's Online   2 Members, 0 Anonymous, 838 Guests (See full list)
