Ouch!
I need to have my disks machined but I thought I'd check out the cost of replacing the whole rotor assembly (disk/hub) while I'm at it. The price from Repco in Western Australia is an eye-watering $203 each! I've replaced Holden disk rotors for about $30ea so this seems a little OTT to me...
Can anyone suggest an alternative - one that doesn't require new calipers, or any special engineering work?
Thanks,
Hayden.
https://www.classiczcars.com/forums/topic/16038-replacement-rotors-aus/
Hayden, try Perth Brake Parts in Welshpool.
Most mechanics get their brake rotors, callipers and pads from there. They also re-sleave leaking master/slave brake & clutch cylinders too.
