Posted May 28, 200519 yr comment_125425 Hello, im having a serious problem trying to get my 1972 datsun 240z started. All the plugs are recieving a spark and fuel is reaching the carbs without any problem. The engine will just turn over until it lets out a massive backfire in which it actually blew my muffler in two, however, it only does this occasionally. Does anyone know what the problem may be? Link to comment https://www.classiczcars.com/forums/topic/16063-starting-issues-plz-help/ Share on other sites More sharing options...
May 28, 200519 yr comment_125426 Are you sure the timing is right? It sounds like you're getting spark but at the wrong time. Link to comment https://www.classiczcars.com/forums/topic/16063-starting-issues-plz-help/#findComment-125426 Share on other sites More sharing options...
May 28, 200519 yr Author comment_125427 it could be the timing cuz i did replace the distributor rotar, cap, and new wires. how would i go about adjusting the timing. I looked it up quickly in a chiltons manual but left me confused =( Link to comment https://www.classiczcars.com/forums/topic/16063-starting-issues-plz-help/#findComment-125427 Share on other sites More sharing options...
May 28, 200519 yr comment_125428 Was it running properly before replacing the cap? Could it be 180 degrees off? Are you sure you replaced the wires properly? Link to comment https://www.classiczcars.com/forums/topic/16063-starting-issues-plz-help/#findComment-125428 Share on other sites More sharing options...
May 28, 200519 yr Author comment_125429 i matched it up with the firing order in the chiltons manual, and i wasnt able to turn the rotar 180* so im assuming thats all correct Link to comment https://www.classiczcars.com/forums/topic/16063-starting-issues-plz-help/#findComment-125429 Share on other sites More sharing options...
May 28, 200519 yr Author comment_125430 and no it has not run for about a year... i went through just about everything in the carbs and ignition and i just dont know... Link to comment https://www.classiczcars.com/forums/topic/16063-starting-issues-plz-help/#findComment-125430 Share on other sites More sharing options...
May 28, 200519 yr Author comment_125434 hmmm im lost... i still cant figure it out Link to comment https://www.classiczcars.com/forums/topic/16063-starting-issues-plz-help/#findComment-125434 Share on other sites More sharing options...
