usafsra Posted May 8, 2002 Share #1 Posted May 8, 2002 I have a recently purchased 72 240z. I just noticed it has carbs off of a 73. The junky Hitachi carbs (Flat Top). I want to put the originals on, but need a few answers first. Do I need to replace the manifold to fit the older carbs? Anything else I should know about the carb switch? Thanks for your help. Link to comment Share on other sites More sharing options...
beandip Posted May 8, 2002 Share #2 Posted May 8, 2002 No your present intake manifold is fine , in fact if it is a #36 some people think that it is better than most. You will need to do some changes in the linkage and I f you are running the stock air cleaner that also needs to be from the early carbs. Thats all I can think of. My '73 has the early SUs , they are simple and work great ! ! You should be able to come up with a set for $ 100. to $150. I know of a complete set that are good , he has a the whole setup let me know if you want his address.. ZZZZZEEEE ya . Link to comment Share on other sites More sharing options...
usafsra Posted May 8, 2002 Author Share #3 Posted May 8, 2002 Thanks. Can you send me his address? My email address is mwoodruff@inchord.com. Thanks again. Link to comment Share on other sites More sharing options...
Royce Posted May 9, 2002 Share #4 Posted May 9, 2002 What is the build date of your '72 240Z with flat top carbs? I am just curious if it is a '73 model car registered as a '72. Shouldn't be too much trouble to swich, beandip is correct you will want the air cleaner that goes with the early carbs.Have fun! Link to comment Share on other sites More sharing options...
