Posted May 31, 200519 yr comment_125718 Im doing a 260z 2+2 for my gf and she needs powersteering . I have the steering from a 280zx has anyone used the Power assisted steering from one of these in there zed!!cheersRichard Link to comment https://www.classiczcars.com/forums/topic/16089-steering-change/ Share on other sites More sharing options...
May 31, 200519 yr comment_125731 If you get this done keep us posted as I'll bet many more first gen Z owners have wanted to do it. Link to comment https://www.classiczcars.com/forums/topic/16089-steering-change/#findComment-125731 Share on other sites More sharing options...
May 31, 200519 yr comment_125734 If the tires are near stock width, even she doesn't need power steering....Zeds have the easiest steering....gets tougher if you go wide however....that's not an easy install from what i've seen. Link to comment https://www.classiczcars.com/forums/topic/16089-steering-change/#findComment-125734 Share on other sites More sharing options...
June 10, 200618 yr comment_170616 Ahh..., Richard, I wouldn't use the 280ZX rack as it's rear mounted to the x-member which means if you turn the steering wheel right the car will go left & vise versa... not a good thing.Nick. Link to comment https://www.classiczcars.com/forums/topic/16089-steering-change/#findComment-170616 Share on other sites More sharing options...
June 10, 200618 yr comment_170630 Check on hybridz.org. Members there have done Mustang racks which look like they're not such a good fit, but the Subaru WRX rack is really a close fit. Not quite bolt in but I don't think you'll find anything closer for p/s on a Z. A search should bring it up. Link to comment https://www.classiczcars.com/forums/topic/16089-steering-change/#findComment-170630 Share on other sites More sharing options...
June 12, 200618 yr comment_170782 check the tire pressures... I have found that a tire thats low on air will be hard to turn, and when filled up to the max pressure, steers way better. plus I go 5 to 10 psi over max, and find I get better grip from the front tires. Tires are going to wear anyways, and with prices on normal tires these days, who cares about getting 50,000 miles out of a tire when the car is driven only 10,000 miles at the most a year. Link to comment https://www.classiczcars.com/forums/topic/16089-steering-change/#findComment-170782 Share on other sites More sharing options...
