  • 1 year later...
Check on hybridz.org. Members there have done Mustang racks which look like they're not such a good fit, but the Subaru WRX rack is really a close fit. Not quite bolt in but I don't think you'll find anything closer for p/s on a Z. A search should bring it up.
check the tire pressures...
I have found that a tire thats low on air will be hard to turn, and when filled up to the max pressure, steers way better. plus I go 5 to 10 psi over max, and find I get better grip from the front tires. Tires are going to wear anyways, and with prices on normal tires these days, who cares about getting 50,000 miles out of a tire when the car is driven only 10,000 miles at the most a year.:)
